deck load progress indicator
On large decks, where you don't have all the layers in view and there are a lot of files to load, you never really know if the deck has loaded until resolume allows you to launch a clip.
So clips not launching is an indicator that the deck is not laded, but I think a visual indicator for this - even as simple as coloring a deck button for the time of launch - would be nice to have.
If this visual trick would indicate the whole progress, say a bar growing in the deck button from 1-to 100 precent, would be even more nice.
