Very Low Fps With only 2 Layers
Max Taste
Post by Max Taste »
Hi there !
Has the title explains I experience some very low performances with only two HD layers using the Add50 blending. I did the benchmark and I have this :
1 layer 35 fps :?
2 layers 19 fps :cry:
3 layer 13 fps...
All my files are in DXV. Here's my config:
nvidia 970GTX with latest driver.
Intel i7-3770 at 3.40 Ghz
DDR3 16 Gb
My computer is very clean (I use it for video editing) and I'm experiencing the same problems on a good gaming laptop of a friend.
Help please !
Max Taste
Re: Very Low Fps With only 2 Layers
Post by Max Taste »
I also have troubles in rescalings the clips, sometimes the auto scaling just doesn't work and I can't type the height or weight and have to adjust it manually with the fader...
are you maybe using your main display from the motherboard display output?
Resolume renders on the card that windows uses to display the main desktop.
you can check the renderer in the log file, go to Preferences - Feedback - view log, search for "Renderer"
Max Taste
Post by Max Taste »
It's okay now. I was on the 4.1.2 version and it seems to have had troubles with the very recent drivers a my graphic card. Thanks !
RiCkYB667
Post by RiCkYB667 »
Hey there, can I ask what version you are running on now? Do you still have issues with low FPS?
