EXPORT as a movie
Astrodomus
EXPORT as a movie
Post by Astrodomus »
Hi there, is it possible to export a complete production as a movie? I am alone on stage and want to run Resolume with Mainstage...
Re: EXPORT as a movie
you can record in resolume, relatively short sequences.
If you have a fixed resolume set then you could record the output with a capture card,
or you could try controlling resolume via midi, from Mainstage,(I dont' know if that's possible)
or use a third party program to automate it, that would have the benefit of being flexible if you want to tweak something.
