Sinc controller for screen slices in advanced output window
Sachin Mhetre
Post by Sachin Mhetre »
It will be useful if there is transport controller for screen slices in advanced output window which provides different sinc options like Audio FFT, easing and other sinc options for screen, then we can put slices under screen in custom sequences as per our choice and will be displayed (played) in same sequence when we sinc it.
Re: Sinc controller for screen slices in advanced output win
Transport controls and clip sequences you should arrange in your layers.
You can assing midi osc, DMX or keyboard keys to control them.
Then you can use the advanced output and Screens and Slices to decide where your layers or composition will be visible in your Output.
You can find the Resolume manual here:http://resolume.com/manual/en/r5/start
