How to use Kinect 1 in Resolume as Video Cam
JanB
Post by JanB »
Hello;
I'm student in art school and I use kinect for my work.
I'm on Windows 8 and Resolume Arena 4
I want to use Kinect in Resolume as a Directshow Capture Devices ( like a Webcam ).
I have try to use OpenNi Virtual Camera ( with Kinect enabled ) in Resolume but it does'nt work; always on a black screen.
I have try Spout too but I think I don't know how to work Spout as well.
How can I do that ?
Re: How to use Kinect 1 in Resolume as Video Cam
a simple Processing sketch with SimpleOpenNi and spout should do that.
the openNi package has example sketches, you only need to integrate a spout example into one of them.
JanB
Post by JanB »
Ok: And how can I integrate a spout in an OpenNi sketch ? with Processing ?
Where can I find a good tutorial on that; I searched on Google but nothing of concrete..
the simplest way would be to look at the spout example sender, and the OpenNi example project into it.
Do the openNi imports in the spout example sender, declare variables, init them, then in the draw method draw the kinect video image, then send spout texture.
both example sketches are explained with comments.
MkUltra
Post by MkUltra »
