master slave systems in arena
we are planning on doing an install in a mall with led screens for the ceiling, pillars and some shop windows and are looking at the possibility of using arena as the media server. is it possible to use different computers for each area and then setup a master slave system where one pc is the master computer for the ui for file/content management and the rest are slaves and feed off from the master??
Re: master slave systems in arena
What you're describing sounds like the perfect application for an external OSC controller.
Arena can easily be set up as Master/Slave but it works best with identical composition structure even if the content is different since it sends the OSC info that's triggered on the master to the slave.
