Bome Midi preset for launchpad!
mattsmithadelaide
Post by mattsmithadelaide »
I've created a bome midi preset which took a while. For someone with little scripting experience you may find it useful!
I'm sure there are better ways to do it etc but I'd love to see what others have done with bome and resolume it can be a very powerful combo!
Only requirement is to have your launchpad set to channel 90 (or else change it!) then midi map it to resolume
Currently I have
3 rows of 16 clips with 2 blank orange illuminated spacer rows
2 Blending types for the three rows select able on the top 6 rhs most column
1 row of 8 clips up top for flash
Bottom RHS Activates a toggle mode toggling the system from preview screen to output screen
Planning:
Launchpad faders for FX and composition dashboard settings
well after all that it turns out you can't upload files or post links so nfi how I can send it your ways! aha
Physalis
Re: Bome Midi preset for launchpad!
Post by Physalis »
Hello,
could you send me please your script. I'am trying to make work APC mini with Bome and Resolume. May be your script will help me understand better the Bome.
Thank you!
Andrey
P.S. I can't even send a PM message... May be with soundclound PM we can contact if it's you of course with the same nickname
francoe
Post by francoe »
Andrey, this is not a good map, just random translations I was using with apc40 sometimes. But maybe you find it usefull if you wanna undestand how it works.
Apc40.rar
(2.02 KiB) Downloaded 640 times
Physalis
Post by Physalis »
Thank you very much, I will test this!
mattsmithadelaide
Shall do!
The biggest thing to get your head around is that input monitor will show the midi in terms of HEX however you programme in decimal. So you'll need to hop on the net and find a hex to decimal convertor. It took me a while to realise that!
I'll send through the file this evening once I zip it!
adriancuervo
Post by adriancuervo »
Hi mattsmithadelaide. I agree, Bome is a great solution to use with Resolume. Can you please upload the file to test it in my mac? I wan't to check if it works on launchpad mini too.
thanks!
Adrian
