Is there a way to stop slices 'snapping' into alignment with other slices?
Its an awesome tool but if you have multiples slices, the latest slice in transform mode will attempt to snap to a number of points (edge, middle etc) of every other slice to the point where it refuses to align properly and jumps a fraction further than desired.
It doesn't happen in edit point mode as the snap function appears to be disabled...but would actually be useful at times.
Arena 5 Stop Snap Behavior...
Re: Arena 5 Stop Snap Behavior...
Try to press Ctrl, when you move slice or point.
http://resolume.com/manual/en/r5/modifiers
Perfect...thanks! (next time I'll RTFM)
We're collecting more options for snapping in this thread viewtopic.php?f=6&t=12528.
Maybe you can add your ideas there on which points you'd like to snap to what?
