Resolume Arena 5.0.1 & Avenue 4.5.1 Updates
"Given enough eyeballs, all bugs are shallow." - Eric Raymond
Arena 5 got a LOT of eyeballs since its release just 6 weeks ago. Many of you upgraded to Arena 5 and put it in front of crowds big and small, lighting up screens and LED pixels worldwide.
There were no MAJOR bugs in Arena 5.0.0. and Avenue 4.5.0. Nobody's cat caught fire, no laptops melted, nobody got hurt. But there are always small bugs in software and we're happy to now release Arena 5.0.1 & Avenue 4.5.1. These updates fix a few bugs, just to keep you sailing as smoothly as possible.
Download and Enjoy!
Merci beaucoup Emeric Delavaud for the French translation! Köszi szépen Gergo Fischer for the Hungarian translation. Grazie mille Daniele Penna for the Italian translation. Mulțumesc foarte mult Daniel Radutu for the Romanian translation!
Release Notes
[NEW] Variable DMX output delay
[NEW] Variable DMX frame-rate
[FIXED] Arena can crash when an output is removed
[FIXED] Windows Desktop Scaling causes wrong resolution on Display 2
[FIXED] Crash on selecting BlackMagic output resolution in advanced output
[FIXED] Problems when saving to Cyrillic chars in documents folder
[FIXED] Open Fixture Editor via Arena Menu
[FIXED] Fixture gamma has no effect on the output data
[FIXED] Quartz Composer sources flash rapidly
[FIXED] Advanced output GUI does not like non-latin characters
[FIXED] Soft-Edge not initialized correctly after startup
[FIXED] Blur effect broken when applied to clip
[FIXED] A clip set to 'play once and eject' should not eject the incoming clip during a transition
[FIXED] Show the layer name in the Slice input dropbox of the Layer Router
[FIXED] Regular Mask renders black instead of transparent
[FIXED] Alt drag to duplicate a Slice does not work on input tab (does on output)
[FIXED] When clicking *but not dragging* the rotation handle outside the bounds of the slice, the slice is deselected
[FIXED] Capture card output settings aren't saved in advanced output preset
[FIXED] Comp name gets updated before Save As... dialog is confirmed
[FIXED] Move Midi clock sync indicator to statusbar
[FIXED] Don't apply composition bypassed to output of virtual screen
[FIXED] Advanced output loses focus when mouse is moved over browser panel
[FIXED] Advanced Output mouse over help often says Switch to this Deck
[FIXED] Buggy polygon slice behaviour
[FIXED] Changes in Fixture Editor are not updated in Input Selection when advanced output was closed during editing
[FIXED] When the fixture input is dragged outside the input canvas the pixel data shown is not black
[FIXED] In preferences the dmx input output list always jumps to the top on adding or removing IOs
[FIXED] The New Output button in DMX preferences is only active to the middle of the button
[FIXED] Can't CMD-D slices or masks when in OutputTransform > Edit Points
[FIXED] If you hold ALT after you started a drag snapping doesn't work
[FIXED] Enable 'Bring forward' and 'Send backwards' for multiple slices
[FIXED] Edit slice name on single click
[FIXED] Multi select Bypass in slice list
[FIXED] Multi select Popup Menu in slice list does not work
[FIXED] Multi select by dragging does not work on second screen
[FIXED] When Screen name is changed it is displayed correctly in the list but not in the header above it's params
[FIXED] Add duplicate option to popup when multiple slices are selected
[FIXED] Advanced output on PC does not pick up changes in resolution in the screen selection drop down
[FIXED] Delay on DMX input preview
[FIXED] Dead-lock when renaming 2 or 3 screens after each other
[FIXED] Weird behaviour when bypassing multiple selected slices at once
[FIXED] Slice Selection Bugs
[FIXED] If you have selected a folded screen you can't select slices (of other screens) by clicking in the input editor
francoe
Re: Resolume Arena 5.0.1 & Avenue 4.5.1 Updates
Post by francoe »
Wow, that's a massive number of fixes for such time! :)
