So I've come across yet another weird issue.
Ive seen this happen on 4.2, 5.0 and 5.1 on a mid 2012 macbook pro and two 2015 macbook pros. With single DVI or 2 DVI out setups.
When I try to scroll through my deck the frame rate jumps to around 80 or 100 fps and the clip that is currently playing lags. The moment I stop scrolling. It gets back to normal. This doesnt happen all the time. But the frequency has been increasing.
I've had my KORG nano Kontrol 2 plugged in at all times. If you guys think maybe that's related.
Any ideas what could be causing this?
Macbook pro, Scrolling causes frame rate jumps and lags.
Re: Macbook pro, Scrolling causes frame rate jumps and lags.
We've heard of this happening on Mavericks and Yosemite. Upgrade to El Capitan and it's gone.
