Drag n drop multiple clips to same column
when drag-n dropping multiple clips to the decks from the browser or outside arena,
it would be very nice to have ALT as modifier to be able to drop the clips into a single column, on different layers.
Re: Drag n drop multiple clips to same column
Great idea!
Try dragging a bunch of clips onto the column trigger ;)
Joris wrote:Try dragging a bunch of clips onto the column trigger ;)
nice, but how do I make the clips start from any layer other than layer1?
The whole purpose of this would be that no re-arranging of the clips would be necessary, you could see exactly where the clips will land starting from a given slot, and they also could create missing layers just like multiple clips create the necessary columns now.
It's so hard to please you, Ravensc. I feel like nothing we do is ever good enough for you ;)
just bringing a few ideas to make your great software even better ;)
