add currently opened composition to composition list browser
I keep compositions and files together in a folder of their own...
so I accidentally closed a deck instead of duplicating and couldn't find any other way to re-open that closed deck, just copying it to the compositions folder, opening it - still not in the list, - saved it, then it appeared, opened the closed deck - re saved, moved back to the original location.
So it would be an improvement handling these kind of situations, if the currently opened composition
- would appear regardless the composition file's location.
- would appear on the top of the composition list, so you don't have to search for it in the list anyway.
Re: add currently opened composition to composition list bro
ravensc wrote:So it would be an improvement handling these kind of situations, if the currently opened composition
Yes +1
ravensc wrote:- would appear on the top of the composition list, so you don't have to search for it in the list anyway.
Not only I would love to be able to organize the comp list alphabetically as well as chronologically but just like the files and effects it would be awesome to have a search box to find things easily.
