hallo, in resolume 5 the fft input only shows the level in the frequenz chart, but do not move the parameters.
please hlep.
r.h.
fft do not work in 5
Re: fft do not work in 5
turning the gain up doesn't help?
in preferences / audio there is also a gain setting for the external fft input.
no way. the waveform is shown on the right place. and its moving to the top in every band correct.
but the little triangle which is normally animated by the choosen frequency range is not moving.
somtimes it is moving completly from one side to the other but randomly and without any possibity to control it.
win 7 64 bit . resolume 5.0.1 demo.
in former versions(from v 1.1)
it was somtomes nessecary to change the buffer size an that problem was solved, but this time this trick does not work.
htx for help.
r. heinrich
htx for help.
r. heinrich
westfernsehen, leipzig
hallo in addition, the magenta colored triangles which are for the audio parameter are working proper.
the green triangles which are for the video paramters are not moving anyway.
thx for help,
r. heinrich
thx for help,
r. heinrich
it works nice for me on mac and win7.
could you post some screenshots of the parameters and audio preferences?
hello everybody.
sorry but it sounds like really really crazy,
but,
if we open 5.0.1 a) with a complete empty composition, b) with a composition saved from an empty
composition on start up, then and only then the fft does not work!
if we open resolume with an empty or on empty comp based comp, and do nothing else than open the example comp, it works completly as usual.
and when it works, it works with new empty comps and based on new empty comps, till the next restart of resu.
absolutly crazy.
but after saving an example comp with new name, ti works on startup with this as last comp absolut correct,
and so we think its possible for us to life with.
thank you so much for all ideas, and the great support of Joris.
rene
but,
absolutly crazy.
rene
