4 Screen duplication plugin please test
hive8
Post by hive8 »
Updated!
Win: V1.001 with black BG over everything and VS2013 compiler.
OSX version coming over the weekend.
I think version 1.000 is finished... :)
Plugin can take a input and duplicate it 4 times, each duplication can be scaled and moved independent, also your able to turn each duplication on and off, can be mapped to midi or OSC (strobe effect).
More to come in the next version probably end of week
Could users test for me and see if it works on other machines, win only as of now till the mac comes back.
Suggestions for more features are welcome, please let me know and I will try to add them.
Thx Joris for the help i got everything figured out :)
To note for this version the string to show the pixels and % on the slider is currently hard coded to a resolution of 1920 x 1080 will change later.
H8_FFGL4ScreenV1.001.zip
WIN updated 1.001
(7.6 KiB) Downloaded 1267 times
FFGL4Screen.bundle.zip
OSX 1.000
(9.29 KiB) Downloaded 1261 times
Sadler
Re: 4 Screen duplication plugin please test
Post by Sadler »
First glance it works here on Win7, 5.0.1.
Requires the 2015 VC runtime to be installed.
hive8
Post by hive8 »
thank you for pointing that out, didn't notice that since I use Visual Studio 2015
Looks like u need the following VC2015 dist
http://www.microsoft.com/en-us/download ... x?id=48145
hive8
Post by hive8 »
Added the OSX version, please test and let me know some feedback
I love how a few months ago, everybody was falling over themselves, trying to figure out how Eyesupply was doing their inputmaps and screen bumps. Now here is a plugin that does exactly what they've been doing for the past 3 years, and nobody even raises an eyelid.
Keep up the great work, Hive8. You're on the right path!
ReggieUnderground
Post by ReggieUnderground »
Thanks for adding a Mac version!
Kadete
Post by Kadete »
I already said thanks on the other post he did with the same subject :P
I thank again :D,It's a must for sure!
DHoude
Post by DHoude »
Tested a bit. Works pretty good as an initial release. Job well done!
nice work,
the Move Y parameter seems to work inverted as to I would have expected. (top left corner being the 0x,0y).
a suggestion, if I may: if the Screen enable parameter would be a slider, it could be animated within resolume so the plugin could be used more creatively, without any external stuff.
hive8
Post by hive8 »
Could I will add those filters, I will actually keep the screen on / off button but will add a brightness control,
That is also a good idea since you can change the brightness of the individual screens :)
