Intel NUC is working like HELL
Sportinger
Post by Sportinger »
i just want to leave this here.
elgarf
Re: Intel NUC is working like HELL
Post by elgarf »
Can you provide exact configuration of your NUC?
Sportinger
sure thing.
NUC6i5SYK € 409,72
Chipsatz: System-on-a-Chip (SoC) • CPU: Intel Core i5-6260U, 2x 1.80GHz, 4MB Cache, 15W TDP • RAM: 2x DDR4 SO-DIMM, dual PC4-17000S, max. 32GB (UDIMM) • Festplatte: 1x M.2/M-Key (PCIe 3.0 x4, M.2 2280/2242) • Schächte extern: N/A • Schächte intern: N/A • Grafik: Intel Iris Graphics 540 (IGP), HDMI 1.4b, Mini DisplayPort 1.2 • Erweiterungsslots: N/A • Anschlüsse: 4x USB 3.0, 1x Gb LAN (Intel PRO/1000), 1x Klinke, Cardreader (SD/SDHC/SDXC), NFC (Header) • Wireless: WLAN 802.11a/b/g/n/ac, Bluetooth 4.1 • Audio: 7.1 (Intel HD Audio) • Netzteil: 65W, extern • VESA-Halterung: 75x75, 100x100 (inkludiert) • Abmessungen (BxHxT): 115x32x111mm • Besonderheiten: Nettop, Kensington Lock, Infrarot-Sensor • Herstellergarantie: drei Jahre
16GB HyperX Impact DDR4-2133 SO-DIMM CL13 Dual Kit € 83,60
256GB Samsung SM951-NVMe M.2 2280 PCIe 3.0 x4 32Gb/s MLC Toggle (MZVPV256HDGL-00000) € 144,90
i have up to 1,6 Gbyte/s in cristal diskmark. this is just insane.
elgarf
Post by elgarf »
No surprise, that resolume works good with such config :)
He2neg
Post by He2neg »
Great you want to share your experience with us, can you pls run the Benchmark test so we can compare the Nuc to other Laptops.
viewtopic.php?f=11&t=11093
~Berlin~
Sportinger
done. I updated the spreadsheet.
2 1920x1080 displays
480p -
clean20+
noise20+
1080p -
clean17
noise10
4k -
clean 3
noise 2
650€
without a doubt, the cheapest solution in terms of power. I will try 3 display setup the next weeks. Also multiple usb capture cards from black magic.
Iam still blown away. And this is only the i5 version. the Nuc with i7 skylake and iris 580 will be a 4k Monster.to be released in summer i hope.
He2neg
Post by He2neg »
Just keep in mind that the onboard grafic card solutions are not nativ supported with arena & the mapping features.
So as long everything works you can be happy but it may have some point were the intel card just wont work the way you want to.
~Berlin~
Sportinger
I just tested NUC with a 3 Display setup. 2 displays daisychangend via mini displayport(3440x1440 60p, 2560x1440 60p) and another dipslay over HDMI (1920x1080 60i)
benchmarking 1080p was spread over 2 monitors in multiple slices and one control monitor (changing the controll monitor didnt effect the framerate)
clean 14
noise 7
i also added a Intensity shuttle pro and feed the HDMI out directly back into resolume. Digital analog feedback i guess, was fun to play around with ;)
The latency seems to be 3 to 4 frames or around 130ms. (the refreshrate of the monitors and the measurevideo where 30fps)
As i read the specs of NUC, 3 out of 4 usb 3.0 ports have there own pcie lane.
One should be able to connect 3 Intesity shuttle's then. Will test the secound on monday.
At this point, i realy consider to never buy a normal PC again. seems to be pretty easy to extend the 4x miniPCie port and raise it to a full slot (perhaps for Decklink quadro or something).
The i7 with iris 580 will have 72 Execution Units, that are one thrid more than the current setup. With direct acces to the 32GB DDR4 it will be a shir monster. I wonder how many daisychanes i can make
He2neg wrote:Just keep in mind that the onboard grafic card solutions are not nativ supported with arena & the mapping features.
i tested it with or 40 slices on 3 screens and in advance mode. Everythings working like it should. Can you recommend some examples ?
He2neg
Post by He2neg »
Some Problems reported you´ll find here :
viewtopic.php?f=12&t=12808&p=52508&hili ... ard#p52508
viewtopic.php?f=12&t=10001&hilit=intel+card
But as i said ;) test it, and if it works fine you´ll have a cheap and strong machine
Be happy about it...
~Berlin~
