Script for replace absolute paths to relative in composition
elgarf
Post by elgarf »
HI.
Wrote this simple powershell script, that replaces absolute paths to relative in resolume compositions. It takes one parameter, which is path to your composition.
For using, put your composition in folder with your footages, then apply this script.
Oh, it works only if you loading composition by double-clicking on it in file explorer, otherwise working path is resolume directory.
RelativePaths.zip
(852 Bytes) Downloaded 616 times
DayVeeJay
Re: Script for replace absolute paths to relative in composition
Post by DayVeeJay »
Very nice!
