"Projector need corner pin"
Projector seller advice to me.
This is true??
Do projector spec need corner pin for projection mapping?
Re: Do projector spec need corner pin for projection mapping
Corner Pin is just the ability to move/pin corners of a squared projection as desired. As in a Keystone effect/setting.
Well.... short answer: No! You don´t need that, although most projectors have that as built in.
That´s why you use Arena ; )
Arena will do that and MUCH MORE.
Paulo
Paulo
The best way to map with any projector is to use the projector's native resolution with NO keystone and NO digital zoom and that'll give you the cleanest results you can get. All your mapping will be done in Arena.
Thank!! Arena seems like enough mapping!pfelberg wrote:Corner Pin is just the ability to move/pin corners of a squared projection as desired. As in a Keystone effect/setting.
Paulo
Thanks again for help!!Oaktown wrote:The best way to map with any projector is to use the projector's native resolution with NO keystone and NO digital zoom and that'll give you the cleanest results you can get. All your mapping will be done in Arena.
