FFT Input Gain Bug
AdevProjects
FFT Input Gain Bug
Post by AdevProjects »
I found that the audio FFT input gain control in audio preferences does not apply on startup until you open the preferences window. I am currently using Arena 5.0.1.
To reproduce:
1. Save a composition with an external audio FFT input on a parameter.
2. Close and then restart Arena so it restarts the program then reopens the comp.
3. Expand the effect/parameter so you can see the FFT audio input level
4. Open the preferences window and note the level change as the gain control is applied.
Re: FFT Input Gain Bug
Confirmed and ticket made, thanks for letting us know!
