Hey guys sorry if this has been asked before but I didnt see anything like it.
Does anyone know of a plugin that exists that will allow for freeform creation of 3D objects that can be manipulated in realtime using dashboard controls.
For example the creation tool that video copliot has made for after effects (videocopilot.net/products/element2/), but having realtime control over the objects size, shape, texture, background, etc from within Resolume.
						Object creation plugin
Re: Object creation plugin
Check out mullimin. It has a realtime plugin for after effects.
On a Mac, you can use AESyphon to get a live preview from Adobe After Effects into Resolume using Syphon framework.
Any more plugins like that for PC?
									AE & Cinema 4d at http://www.loop-video.hr
				dfroelicher
Wow, really cool.
Do these allow object manipulation through Resolume's controls.
Need to be able to control through DMX the size, shape, distortion, etc from a lightboard.
That's not a solution since AE isn't nothing realtime.
I bet you to try to develop a vvvv sketch and plugin it to resolume through spout (you can load 3d objects, send/receive osc mesages, and almost everything). I think you can do the same with Magicmusicvisuals.
Anyway, check out the spout site to see is there other software that can manage 3d objects and fits with your skills.
http://kineme.net/Kineme3D with Quartz does allow what you want.  You can also map everything from the light board with dashboard controls too.  Actually runs pretty good.  Mac Only.
If you want to do things on PC, use Touch Designer/Spout into resolume.
Magic Visuals has object has mesh support but not textures or anything more sophisticated than that.  It is real-time however and has many excellent features besides, including spout and syphon.
