Rename columns
Rename columns
I would LOVE to have the ability to rename columns the same way I can rename layers and be able to use that text string to launch the column. Being able to do that would really simplify my work flow and allow me to insert new columns in comps without having to change all my OSC cues in the control computer.
In an ideal world, I would double click on the column and enter a unique name (ie. VQ1, VQ1.5, VQ2, etc...) and launch the column with OSC (/trackVQ1/connect/ 1 or /track/VQ1/connect/ 1 or trackwithname/VQ1/connect/ 1)
I would also like the ability to launch next and previous column with OSC (/tracknext/connect 1 or /track/next/connect 1) and (/trackprevious/connect 1 or /track/previous/connect 1)
sleepytom
Re: Rename columns
Post by sleepytom »
+1000 for this :)
thetylerherron
Re: Rename columns
Post by thetylerherron »
Heck yeah! +a few for that.
Re: Rename columns
Oaktown wrote: In an ideal world, I would double click on the column and enter a unique name (ie. VQ1, VQ1.5, VQ2, etc...) and launch the column with OSC (/trackVQ1/connect/ 1 or /track/VQ1/connect/ 1 or trackwithname/VQ1/connect/ 1
+1, but adding the rename option in the right click menu instead of double click.
btw, this is the exact situation you describe why I use the layer 1 clip names in my Controller.
Re: Rename columns
@ravensc - Yes I know and I love that functionality in your controller but for most of the installations/shows I do, I need to be able to build cues that use DMX and OSC concurrently with timecode (or keyframed from a timeline).
projectneptune
Re: Rename columns
Post by projectneptune »
I would also really love this feature! "Column Go!"
vj granda
Re: Rename columns
Post by vj granda »
+ 1
Re: Rename columns
Hell YEAAA..... +1
