Playhead Jump
cat
Playhead Jump
Post by cat »
1 thing I'd like is a random playhead that instead of every frame random jumps to a random position every x frames ( or beats, with a bpm function, which would be good for timeswitcher as well!) I use quite a few long loops so it would be good for me, not so if you only use short ones, but what the hay!
But I'd prefer bugs fixed first, so just bear it in mind for the fututre!!
seex
Post by seex »
I think im using something similar:
Same clip in first five chanels, a long clip with the input point set to diferent frames and continue on activation. You can limit the output point to choose completley diferent parts of the clip but continue on activation while the clips are in kaoss mode will make it dificult to hit the same frame. Play with chanell switch speed and use only one layer and deck (only the five clips).
A bpm tap wuld be great
