Fast Switching Output Preset
meister_k
Post by meister_k »
Hi!
Is there a way to switch the Output Preset Fast?
Would be great to switch it over Artnet.
Re: Fast Switching Output Preset
advanced output presets can't be changed remotely.
what are you trying to accomplish?
maybe it can be done an other way.
meister_k
Post by meister_k »
I have a LED Screen consisting of 5 pieces.
Sometimes all 5 Elements should be one big screen and sometimes i want every element show the same hole Picture.
there are a few ways you could do this without having to switch output presets.
one way would be:
so assuming you have your 5 piece led screen set up horizontally,
creating a screen with its output set to virtual,
then create 5 further slices so you have 6,
the most bottom one's input should be composition, the other slices set to layer 3.
now resize the 5 top slices to occupy a different 1/5 th of the output you have each.
save'n close
place a layer router in layer 3 set input: layers below, this will be your switch to have the 5 LEDs the same content each.
now by launching the layer router clip or anything playing in layer 3 will be shown in the 5 LEDs the same way, and if layer 3 is empty then the 5 fixtures will act as one big display
