After lots of frustration I've found a solution to make MPEG Streamclip work on El Capitan (and probably other versions of OS X). Apple decided to get rid of the MPEG2 component that Streamclip uses to encode videos.
1. Download and extract: https://dl.dropboxusercontent.com/u/825 ... ponent.zip
2. Copy extracted file to /library/quicktime
How to make MPEG Streamclip work on newer versions of OS X
Re: How to make MPEG Streamclip work on newer versions of OS
I already have this one on my folder. Is this different than the one you've attached?
- Attachments
- Screen Shot 2016-04-11 at 1.02.28 PM.png (34.48 KiB) Viewed 17142 times
Re: How to make MPEG Streamclip work on newer versions of OS X
I honestly cant remember off the top of my head. You could try backing up and replacing yours
Any chance you can put this file up again?
BeeblePete
I've written a guide to supporting MPEG Streamclip in El Capitan and newer versions of Apple's OS X:
MPEG Streamclip DVD Fix
It includes pointers to where you can get the QuickTime component. Hope this helps!
Beeble's link is down. If anyone needs a copy please PM me
ashmotif200
Hey, is it possible to get an updated link please
Ditto here. Does anybody have this MPEG StreamClip component available for downloading?
TIA
s99p
TIA
s99p
