display problem
Manu_
Post by Manu_ »
hi,
when I want to display dual monitor, the one for the output is working fine but the one on my control pannel display nothing. What can I do to have it on each monitor? Thanks for your help and for your software.
Manu
That,s not possible (yet) displaying it twice would make everything toooooo slloooooowww ...
You can do it with the DVDmax feature of a Matrox videocard.
View-Master_
Post by View-Master_ »
I was toying around with the same thing lately. And I didn't really like de DVD-MAX output since it's not smoothed. And the speed isn't all that either. I found however that the zoom function of matrox works deliciously. You just select the little video window as the zoom aerea and it works fine. No mouse in screen. No plops on your output. And you can adjust the smooth. You can even decide quickly if you want the TV-output to overscan or not.
DearGod. I sound like a salesman.
