Strange behaviour with Lauchpad S
karamasov
Post by karamasov »
Hi!
Pretty sure this question is valid, even if it may intersect somewhere with Novation support.
I have a column trigger via MIDI problem.
I have removed the MIDI trigger for Column triggering. (but no clips ignore column trigger when mouse clicking).
But Arena will trigger the column anyway, when receiving MID note E1 chn.1 from the Launchpad.
I have turned off all other MIDI functionality on tha machine, so nothing should interfere.
Any hints?
Re: Strange behaviour with Lauchpad S
have you checked Application Midi Mapping and Composition Midi Mapping for the column 1 assignment?
karamasov
Post by karamasov »
Hi, yes, I have no Midi notes assigned to any column in either Application or Composition midi map. No DMX, OSC or keyboard either, for that matter, just to make sure :)
in application midi map, there is a Deck , and a Layer focus mode for assignments have you checked both?
karamasov
Post by karamasov »
I just deleted all old prefs and started form scratch, and that, as always I guess, worked. Thanks! The "Deck/Layer setting is important to remember, yeah.
