Hello there;
I'd like to sync live and resolume. So just as mentioned I have downloaded the Yoke but even though it's been installed correctly on my PC, I can't see any new Midi port in my ableton
but i can see yoke midi port in my resolume.
The only MIDI port I'm getting is Michrosoft GS Wavetable Synth...
I'm using a PC, Windows 7 and would like to use both softwares on a single computer.
Thanks in advance
						live - resolume
Re: live - resolume
Hey Ehawes,
The best way for syncing Ableton Live and Resolume, is using MaxForLive.
This blogpost will show you how.
http://resolume.com/blog/tags/Max_for_Live
