Resolume with 3 Christie Projectors
medialightnyc
Post by medialightnyc »
Hello can anyone direct me to info on connecting 3 projectors to Arena?
I will be using 3 D12HD-H DLP projectors. I read the manuals from the Christie site, but I am unsure if I network the 3 together or if I need additional hardware. If someone could point me to a post or link I would be grateful.
Thank you.
pfelberg
Re: Resolume with 3 Christie Projectors
Post by pfelberg »
The basic stuff is like...
1. You´ll need a 4 output graphic card. First output is for Resolume´s gui. The other 3 you will connect each to a projector. In advanced output, create your slices and select the proper display output (projector) for each one.
2. You can have a 2 output graphic card. First output is for Resolume´s gui. The second one you will connect to a Matrox Triple Head to Go (for instance). Each output of the MTH2G will be connected to one of your projectors.
In Advanced Output all slices will use one single display device, splitted/expanded between your three projectors.
Those are the basic options.
medialightnyc
Great, thanks for the reply. I appreciate the help.
medialightnyc
The job went great. I'll post pics in Gig picture thread.
