5.1 crash on loading
Straight-Disorder
Post by Straight-Disorder »
before all, excuse my english, don't have time to use google traduct or a "good speak english friend" help..:)
My problem is simple, i made the update for Resolume Arena 5.1, try it with two different setup, including my win7 pro setup exclusive for live with only Resolume, and the soft crash on startup..!
I try, as i note it in this forum, to delete all file in the preferences folder or just the simple.xml file but it doesn't work... always crash on startup...
Do you have a explain, am i the only man on earth with this problem? My day was so boring, perharps it's simply normal for me today and things will change tomorrow..:)
Just note that i have a licence since 2010 and never have a issue like that..
Thanks for your help,
Resolume power ('till now..:))
Pascal
Straight dIsorder
AsusTek Republic Of Gamer G73Sw
Windows 7PRO 64 bits
Intel Core I7-2630QM CPU 2GHz
Ram 8Go
STRAIGHT DISORDER
[Audio-]Visual [Live] Works
contact@straight-disorder.net
http://www.straight-disorder.net
kaloneros44
Re: 5.1 crash on loading
Post by kaloneros44 »
Τhe problem is in the following file, ......\Program Files\Resolume Arena 5.1.0\ScreenSetup.dll
Ιf you replace it with the corresponding file, ......\Program Files\Resolume Arena 5.0.4\ScreenSetup.dll ,The resolume arena 5.1.0 opens normally . <ADMIN EDIT: THIS IS A VERY BAD IDEA. DON'T DO THIS!>
I thought what is purely a bug on software resolume arena 5.1.0 .
You are not alone.
You can install multiple versions of resolume side by side, so if you have uninstalled the previous version just reinstall it, you can get it from the downloads page.
Straight-Disorder
thanks for your answers, that's work fine! ;)
Just a little clarification that can help, you got to do this manipulation before the first launch of Resolume 5.1 so do not start the program at the end of the installation as proposed by default.
'will try new cool features now ;)
Have a nice day!
Pascal
Straight Disorder
Ram 8Go
STRAIGHT DISORDER
francoe
Post by francoe »
I still have this problem with 5.1.1
I don't undestand what's happening? I've uninstalled all, try'ed again and always crash.
Can you clarify this, because makes non sense to me, do I need to manually copy the .dll from 5.0.4 and replace the new one to make it work?
Why? What's wrong with the new .dll?
kaloneros44
If you replace the dll file just the resolume arena 5.1.0 opens normally . Nevertheless it has function like the 5.0.4 .
I said the above as verification that the arena 5.1.0 is the problem and not the pc of each user .
I think the ScreenSetup.dll file has compatibility problem with some graphics cards .
francoe
Post by francoe »
Oh, thanks kaloneros. I've believed that was a bug fixed on 1.1, but you say is just a compatibility issue between the library and certain gpus. I will reinstall all again right now. :mrgreen:
kaloneros44
I hope that soon the resolume arena 5 will become stable and professional like resolume arena 4 .
francoe
Post by francoe »
Excuse me if I'm being repetitive and boring, but will be able to run 5.1 or this is a permanent change?
I mean, my laptop haven't the newest gpu, but still can run 5.0.4. Do I need a more powerfull machine or this is a bug?
The library replace don't work for me, because I just wanted to try the new features (I missed that before). I want to play around with it to see how dev is goin'on.
kaloneros, stability on 4 was a long way... is our patience prize. :)
It's a bug. If you can run 5.0.4, you should be able to run all 5.x.x versions.
