Decklink Duo 2 Outputs not available
mrfipe
Post by mrfipe »
Hello,
I bought a Decklink Duo 2, but resolume only shows the options to select the resolution in the first two outputs, in the third and forth only lets select but no options, is this normal?
3Media servers i7 860 8GB RAM 240GB SSD Nvidia 760
1Media server i7 7800X 16GB RAM 240GB SSD Nvidia 1080
1Media server dual Xeon E5 2650 V2 32GB RAM 240GB SSD Nvidia 1080 + 970
1MacBook Pro 15 Retina i7 16GB RAM 512GB SSD Nvidia 750
Re: Decklink Duo 2 Outputs not available
Oaktown pointed me to this excellent article that explains about port mapping on a Quad2 card. Apparently the same goes for a Duo2.
Long story short, by default the four output channels are mapped to two SDI outputs, and two SDI outputs are "unused". You'll need to change this in BM's setup software and the article explains how.
mrfipe
Post by mrfipe »
Thank You Joris!!! You are awsome!!!
Thank Oaktown. I didn't even know what he was talking about at first ;)
