Playback speed controlled by audio
Martians
Post by Martians »
I'm wondering if it is possible to control clip playback speed with FFT? Obviously it would have do it incrementally, as in moving forward a bit each time there is a beat..
Re: Playback speed controlled by audio
This is one of those things that we'd love to do, but never find the time for. There's always something more critical that requires attention :(
Martians
Post by Martians »
That's good to know. I've been using Soundkeys in AE to pre-render clips that are played back this way, but having it directly in Resolume surely would be killer!
I have a workaround for you,
here is a short video on how to use fft for parameters in resolume which don't have FFT yet,
you'd need to change the OSC address in the plugin to
/layer1/clip2/video/position/speed
leave the FFT on '>'
and have the clip unpaused
Martians
Post by Martians »
Wow, Thanks Ravensc - Haven't spotted your reply until now :)
Cheers,
Martin
Martians
Post by Martians »
Unfortunately, the IR OSC plugins don't work in Resolume 6.
Will you be adding this function natively at some point?
At some point, yes. Right now we are focusing on making all the dozens of new features that we've added to Resolume 6 as stable as possible.
Martians
Post by Martians »
Any news on this situation?
the IrOSC sa plugins have a 64bit build, which works with Resolume 6
http://visution.com/downloads
Martians
Post by Martians »
Thanks Zoltán!!! That's great to know... Will grab them right now!
