I have a strange problem,
sometimes when I set the the in/out points of a clip, on composition reload these point are reverted to the 0-100% positions.
The strange thing is that this doesn't always happen and the saved composition opened in 5.0.2 recalls the points properly. Sometimes I set the points with the keyboard shortcuts this seems to trigger this behavior but I'm not sure.
Attached the composition file in this state.
clip in-out points not recalled properly
- Attachments
- arte - zenes -auto.avc.zip
- (12.66 KiB) Downloaded 211 times
Re: clip in-out points not recalled properly
I think I know what's causing this,
this seem to happen when the VideoClip/settings/parameters/parameter(duration) and the actual
values(StopValue - startValue) calculation doesn't match (within about +-0,00014648437492)
so the calculated and set durations are not equal.
Seems that 5.0.2 doesn't care about the calculated duration in this regard.
Confirmed and ticket made. Thanks for reporting it and the XML detective work. It's a tricky one to recreate, probably wouldn't have found it without your help!
