Will this build get me by?
DakSom
Post by DakSom »
I am building a new production computer because my current computer isn't quite cutting. Will a build of these parts get me by?
Mobo- ASUS Micro ATX DDR3 1600
CPU- i5-4950
GPU- Zotac GTX 1050Ti (the compact version)
SSD- Crucial 275GB
Side note- I was planning on getting windows 7 just because its about half the price of ten, I dont know if this would affect much.
Thank you so much!
Anothertom
Re: Will this build get me by?
Post by Anothertom »
I suppose, maybe, it depends on what you're trying to do with it. And you've quoted a motherboard which turns into RAM specification.
You've covered most of the major points fairly well, personally I might try to get a larger SSD or even move to an NVMe drive. If you've got the money for a new 1050 Ti, maybe look at second hand deals on ebay/craigslist... you might be able to find a more powerful card for the money.
Personally i'm not really a fan of x50 cards, so maybe look at a 1060 if you can push your budget a bit.
N.B. If you're looking at an OEM win 7 license then that would then be locked to the hardware, if you want to be able to change systems eventually you would then need to buy a new license. win 7 vs 10 won't have a major impact on performance.
djsimshady
Post by djsimshady »
How much did you end up spending on this upgrade?
