progressive delay between 1,2,3,4 layer in loop! resolume 5
dmnik111
Post by dmnik111 »
Hello. I found a issue with syncronysation with clips in one column -
in resolume 5-5.1.2 - i added four layers and 1 clip for all them. timeline for all clips is looped, for 8 hours delay between 1 and 4 layer is ~5-10seconds. Resolume for windows, I tried diffrerent clips, tested for andother windows machine (win7,8,10), created new composition and so on without any result. it is issue only for windows, for mac no delay.
delay between 1 and 2,3 is not so big, but for time it grows. You can see this bug if open advanced output and create new 4 slices and select source for each own layer. When you switch between 1 and 4 layer you can see 2-3 frame delay at begin of lopp at once, and for long time it will be grows.
Resolume, HEEEELP, it is a BIG problem!!!!
p.s. i tested delay for 4 version of resolume - no problem
Re: progressive delay between 1,2,3,4 layer in loop! resolume 5
does this happen too if you set the clip timelines to bpm mode?
Ladin
Post by Ladin »
same problem here..
viewtopic.php?f=12&t=13865
Trying to solve it, so I bought much faster SSD and installing clean build of system.. We will see..
