Transparency on black
AnveG
Post by AnveG »
Hi everyone,
I would know how can I put on one layer some text clip with black background and on other layer with different background.
Can I set on the first layer the black background to Trasparency?
Recap:
LayerUP -> Text Animation with black background
LayerDOWN -> Anythings
with the two layer totally ON how can i see the layer below. :?: :?:
pfelberg
Re: Transparency on black
Post by pfelberg »
If you have any basic knowledge of Photoshop, why not just remove the black BG from the text file and export it as a transparent PNG file?
Yes, you can set it transparent inside Arena/Avenue by using Lumakey or Inverted Lumakey Blend modes.
Paulo
dropping the automask effect on the clip should remove the black
or setting the layer blend mode to ADD at 50% opacity would make a slightly different look.
