help with selecting audio input
peterpeterpeter
Post by peterpeterpeter »
Hello,
If I go to > arena > preferences > audio > external audio fft input and i select primair driver, resolume will detect the audio of my internal microphone and the sound that is played on my pc.
how can I set that resolume only detect the the sound that is played on my pc?
greetings peter
(sorry for bad english)
Anothertom
Re: help with selecting audio input
Post by Anothertom »
I guess you're using windows?
If you to recording devices (right click the speaker icon in the notification area, then recording devices) and set 'Stereo Mix' to be the default device that should do what you're trying to achieve.
You may need to right click and 'show disabled devices' to get it to appear.
peterpeterpeter
Anothertom wrote:I guess you're using windows?
it works!!
thanks a lot
