Please........saving all parameters in resolume!
thx
						Please!!!
				Anonymous
aah ok ... yes global effects are not saved in a deck because it would start loading effects everytime you switch to a deck using the tabs in the bottom of the interface.
also, saving chaos settings in a deck will make the chaos pannel behave very inconsistent and possible unexpected. we,ll make other arrangements for this.
save entire setup would be v e r y useful
Hi Folks,
I have to aggree that saving the entire settings would be very welcome.
Perhaps you work differently Bart, but for me quite often its not decks at all, but layer transperancy settings and effects that really set the mood for a patch that I would dearly love to come back to.
Maybe this could be a Layers save that happens independantly from decks?
Cheeries jj:)
Cheeries jj:)
bart, something like this would be cool
http://www.resolume.com/forum/viewthread.php?tid=1344
