Just made an account here to mainly learn everything about IR OSCSA since there's not enough info online about this amazing plug in and I want to gather this info for others.
I'm trying to learn every subtype of command string that ir osc will read. So far I'm limited to:
-/composition/video/effects..
-/composition/link#... (lots of possibilities using dashboard link but still limited)
-/layer#/video/effects...
-/layer#/clip#/effects...
-Questions I have:
1. What other commands are available for the first command? (Comp/Layer/???)
2. Second Command? (video/link/audio?)
3. Is it possible to choose a layer (/layer1/) and command it to trigger clips/columns in sync? for example clips 1-4 in layer 1 would trigger every step in IR OSC 4 and loop. Specifically started this topic to figure this one out...
MAIN CONCERN:
I actually found a video showing someone mapping IR OSC and when they when into midi map mode and clicked any parameter, an OSC command line in the bottom left of Resolume. HOWEVER I do not have this feature for some reason BUT if anyone could figure out how to display this info.. I'll go ahead and make a topic with EVERY COMMAND possible in resolume with ir osc for reference here.
Here's the video (https://www.youtube.com/watch?v=xbghBPQGmrY&t=5s) at time mark 11:20 is when the command for OSC functions is displayed.
Thanks in advance for anyone who has advice
						Calling all IR OSCSA Experts
Re: Calling all IR OSCSA Experts
Your best bet is to contact the folks at Visution.
Each and every item in the Resolume interface can be controlled via OSC. You can find all the addresses by going into OSC Mapping Mode. Also, I recommend to read the OSC chapter in the manual: https://resolume.com/manual/en/r5/contr ... ontrol_osc1. What other commands are available for the first command? (Comp/Layer/???)
Cool beans. I'll just go and free some extra space on the server for you.I'll go ahead and make a topic with EVERY COMMAND possible in resolume with ir osc for reference here.
