Noobie needs help encoding
shitnema
Post by shitnema »
today i install resolume arena 4.
why external file video MOV can't play in deck?
Re: First Time User - First Time VJ - Question
Why don't you use Arena 5 (The latest release?)
Can you encode your file using the DXV3 codec?
shitnema
Post by shitnema »
already install, do you have tutorial for encode file dvx3 codec?
After you install Resolume, the DXV3 Codec will be on your computer and you'll need to use an encoder such as Adobe Media Encoder ($$ for PC & Mac) or MPEG Streamclip (free for PC & Mac), QuickTime Pro 7 ($ Mac & PC but not available anymore!).
If you need more guidance, you'll find several thread in the forum on how to encode properly for Resolume that will explain to you the preferred settings.
Re: Noobie needs help encoding
The manual has step by step instructions for the most frequently used encoding software: https://resolume.com/manual/en/r5/dxv#e ... v_encoding
