Is it possible to fade between clips on the same layer?
I'm using resolume arena as a simple video playback tool triggered by other software using osc. I want to be able to just dump a load of video files in and trigger them arbitrarily with a fade between each
fade between cl;ips on same layer
OnlineZoltán
- Team Resolume
Re: fade between cl;ips on same layer
I don't suppose you know - when not using fades, is it possible to make the triggered clip only begin playing when the already playing clip has reached it's end?
