Ladies & Gentlemen! Please update your Resolumes. We have released Arena 5.1.4 and Avenue 4.6.4. These new versions fix a few crashes and iron out some wrinkles. Nobody likes a wrinkled Resolume while they're VJ-ing, so hit that download.
Resolume Arena 5.1.4 & Avenue 4.6.4
[FIXED] Crash when triggering clip before deck is loaded
[FIXED] Crash when contextual menu is open and active layer is switched
[FIXED] Crash when switching decks during transition
[FIXED] Desktop is shown for a moment when using cancel to exit the advanced screen setup
[FIXED] Invert toggle on AutoMask effect broken
[FIXED] Transition Mixer dropdown doesn't update when creating a new composition
[FIXED] MulitTask mixer no worky on 5.1.3 OSX10.10
[FIXED] Right clicking parameters in the advanced output changes their range to -1.0...1.0
[FIXED] Request for RGBAW color space in DMX fixtures
[FIXED] Right clicking a slice parameter resets it's value but does not apply it to the slice
[FIXED] Crash: Rotate a polygon slice in output map like a mad man
[FIXED] Distorted image when using odd sized image as a mask
[FIXED] Multiple point selection dragger gets perspective after dragging a perspective handler on a slice
Ironed Out Resolume: Arena 5.1.4 & Avenue 4.6.4 Released
daan.hzndnk
Re: Ironed Out Resolume: Arena 5.1.4 & Avenue 4.6.4 Released
Awesome, thanks so much for the RGBAW.
smoresahoy
Currently getting crashes on startup using 5.1.4 on Windows 10.0.14393 Build 14393.
Usually crashes every other startup...for now switching back to 5.1.2, but thought I would let you know
Could you contact us directly via the feedback tab of the preferences? Please and thank you!
