Help with Resolume + Serato please!
Imagine_Music
Post by Imagine_Music »
Hello community,
I am interested in learning Resolume.
Resolume seems to be exactly what I need for video and projection mapping... but how do I make it work with my set-up?
I am currently using a Pioneer DDJSZ, with Serato. The DDJSZ is a digital mixer, so the controller must be used with a software program (Serato).
Is there a way to use Resolume with this setup?
I saw a program named Syphon which seems to help with this, but from my understanding... that program is only available for Apple computers. I use Windows. I also know of smpte, but I'm not sure if that will work on my setup. Also, I only have 2 decks on my controller... not 4.
I would really appreciate any suggestions.
Thank you very much!
Re: Help with Resolume + Serato please!
If your pioneer device has a midi interface appearing in your OS, then you can map your buttons, knobs, etc, in resolume to program functions.
https://resolume.com/manual/en/r5/prefe ... references
https://resolume.com/manual/en/r5/controlling#midi
jaydeeshow
Post by jaydeeshow »
Yes, I've used since 2014.
Once you open "serato video" you will have a 3 options in the Syphon/routing/external feed in RESOLUME SOURCE.
Left, Right and main.
Chose the one you need.
Best,
j.
