LOW FPS!
jimthx
LOW FPS!
Post by jimthx »
Hi,i have GTX 1070 card and i'am outputting 3 outputs (1920x1080 x 3)
I'am using only background images and Blackmagic Capture Card with 1080i50 input.
My FPS is 15-16
Where is a problem in this setup?
Thank You!!!
Re: LOW FPS!
how are you outputting those outputs?
what is your composition size?
how many layers play at once?
what kind of clips? resolution?
which resolume version?
Re: LOW FPS!
Is your GUI set to a monitor attached to the 1070. Is your 3d settings in the Nvidia control panel set to have resolume using the Nvidia card?
gabonacorp
Re: LOW FPS!
Post by gabonacorp »
jimthx wrote:Hi,i have GTX 1070 card and i'am outputting 3 outputs (1920x1080 x 3)
My FPS is 15-16
Thank You!!!
Are you using a hackintosh?
