Keystone on soft edge.
erikdale
Post by erikdale »
Hello,
I'm trying to soft edge blend 6 projectors for a large composition. All projectors are running 1080.
I was wondering if it is better to keystone before attempting to map it or if I should just try to adjust from flat settings. The projectors are on angles due to the space.
Re: Keystone on soft edge.
I do all my mappings and keystone adjustment in resolume.
I try to keep the projectors at neutral settings as possible.
With soft edge you'll have to correct anyway in resolume and in the case you need to replace your projector, keeping the settings only in resolume will make your life easier.
