USB Audio Interface
atomicphil
USB Audio Interface
Post by atomicphil »
Hi there!
Can anyone recommend a reliable USB Audio Interface to send audio from Resolume to a mixing desk (external for a MacBook Pro)? I've been using a M-Audio Fast Track Pro for like 10 years, but after using it on an event the other day the sound could've been better...looking for a new upgrade!
Thanks in advance,
P
Re: USB Audio Interface
MOTU has a lot of great high quality I/O interfaces but that might be more than what you're looking for.
I've used the Focusrite 2i2 for a few years. Very happy with it's Pre's and A/D/A converters. Price isn't bad either.
What output connectors are you needing? XLR, TRS?
I can recommend Komplete Audio 6 from Native Instruments
HOMEPAGE
Till now never had any flaws with it - And its build like a tank.
greetings
