Moving Videos
DataPhreak
Moving Videos
Post by DataPhreak »
I need to move a whole deck worth of videos to a different hard drive. Is there a way to do this without having to rebuild the whole deck? They're all in the same folder, and it's just the one deck. But it would save me a couple hours.
Re: Moving Videos
choose resolume,
move your files,
start resolume, open your composition
you'll see a relocate bottom on your clips
click one, locate the clips file, and choose fix all in the next dialog.
when finished check and save your composition
DataPhreak
Re: Moving Videos
Cool shit. Thanks man.
Re: Moving Videos
And if your content is spread over many folders and you want to collect it at one place... try this
Resolume Grabber
Best wishes
