Bypass All Composition Effects?
sonnenhof2
Post by sonnenhof2 »
Hey, so I'm doing an interactive project using a Novation Launchpad S as a midi controller to apply affects and switch clips in the Resolume Avenue 3 project.
Want I want to be able to do is have a button on the launchpad that bypasses all the effect layers (they're all video effects in the composition effects layer and pressing a pad on the launchpad causes the layer bypass to turn off so that it shows over the video)
I want to basically create a reset button which bypasses all the effects in the composition so it leaves you with just the video that's playing. Does anyone know how to do that? I'm pretty new to Resolume so hopefully someone can help out!
Thanks :D
Re: Bypass All Composition Effects?
how about mapping all the effect bypass buttons to the same midi note?
4eyes
Post by 4eyes »
Instead of putting the effects on the composition, use an effect clip (with all the effects applied to it) on a dedicated layer at the very top of your comp faded up to 100%. Trigger that clip on/off to enable/bypass all effects.
Bonus in that you can have different sets of effects mapped to the same buttons using this technique. DocOptic has a good tutorial somewhere that uses a similar technique.
DayVeeJay
Post by DayVeeJay »
Put all of your effects midi mappings on Composition Midi mapping and then the reset on Application Midi Mapping. This lets you have multiple keys assigned to the same parameter
