Resolume Arena 5.1.3 Crashing Every Other Startup on new Alienware PC
smoresahoy
Post by smoresahoy »
Hello,
I'm running Resolume 5.1.3 (Tried all other released versions too) on a brand new Alienware R3 15 with a GTX1070, 16GB RAM, Intel 7700HQ, and for some reason Arena crashes on startup exactly every other time. This has been constant and its never once started fully or crashed more than once in a row. On the rotation that it does start, it works perfectly fine. I've uninstalled almost all Alienware bloatware programs except a couple. Most of my other programs installed are Google Drive, Dropbox, Adobe Suite, DAZ, Cinema4D, DriverEasy, etc. I've made sure all my Geforce display drivers are up to date as well as drivers in general using DriverEasy. This is a brand new PC, and I'm making the switch from Mac, so any help would be greatly appreciated.
For some reason I haven't been able to attach my resolume log, so theres a link to it below. Thanks for any help in advance!
https://drive.google.com/open?id=0B6H8I ... VNclNkcW1R
Re: Resolume Arena 5.1.3 Crashing Every Other Startup on new Alienware PC
Are you running the creators edition of win10?
Did you install Resolume using admin privileges?
Standard dumb question: have you un-installed, rebooted, and re-installed?
What is the resolution of your laptop screen? (doubt it matters?)
smoresahoy
dinga wrote:Are you running the creators edition of win10?
It looks like I'm running "Version 1607 (OS Build 14393.1358)"
I installed Resolume using the .exe and just double clicking it...is there another way to install using Admin privileges that I don't know about. Sorry not a super windows expert yet :/
Yes, I've uninstalled resolume and reinstalled many times, with complete shutdowns inbetween. Also deleted Documents folder with each uninstall.
which audio drivers are you using?
also your logfile says Windows 7
so please confirm are you running win 10 or win 7?
smoresahoy
ravensc wrote:which audio drivers are you using?
In my device manager, it says that I'm running Intel(R) Display Audio, NVIDIA Virtual Audio Device (Wave Extensible)(WDM), and Realtek Audio. Side note, Alienware comes with an audio application called Alien Sound Center, should I remove that? Also am I reading you my drivers correctly?
And I am most definitely on Windows 10...
smoresahoy
So I just uninstalled everything 5.1.3, deleted my documents folder, deleted everything Resolume in Users>Username>AppData>Roaming, etc.
Performed a fresh install of 5.1.4, launched straight from the installer when it was finished, and this is the log I received.
Resolume Arena 5.1.4 rev56521
Log started: 14 Jun 2017 2:59:25pm
Logging has started
Operating system: Windows 7
OS 64 bit: Yes
CPU vendor: GenuineIntel
CPU speed: 2781MHz
Number of CPUs: 8
Memory size: 16251MB
System language is: en
ApplicationPath: C:\Program Files (x86)\Resolume Arena 5.1.4
MediaPath: C:\Program Files (x86)\Resolume Arena 5.1.4\media
CompositionsPath: C:\Users\Alec Maassen\Documents\Resolume Arena 5\compositions
UserPresetsPath: C:\Users\Alec Maassen\Documents\Resolume Arena 5\presets
DefaultPresetsPath: C:\Program Files (x86)\Resolume Arena 5.1.4\default\presets
PreferencesPath: C:\Users\Alec Maassen\Documents\Resolume Arena 5\preferences
UserDataPath: C:\Users\Alec Maassen\AppData\Roaming\Resolume Arena 5
CommonDataPath: C:\ProgramData\Resolume Arena 5
CommonDocumentsPath: C:\Users\Public\Documents\Resolume Arena 5
DefaultDataPath: C:\Program Files (x86)\Resolume Arena 5.1.4\default
UserDocumentsPath: C:\Users\Alec Maassen\Documents\Resolume Arena 5
ApplicationVideoEffectsPath: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx
ApplicationAudioEffectsPath: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\afx
Registration valid
Id valid
Serial has not expired
Instantiate midi controller
Instantiate OSC controller
Instantiate DMX controller
Create ApplicationParameterCollection
Create PropertyCollection
Create and initialise composition state object
CompState::init: initialise GlEngineState
GlEngineState::init: start
GlEngineState::init: end
Create application lookups
Create file loader
Start loading application settings
Set Language
Hello = Hello
Looking for unicode font
Unicode font is set to - Lucida Sans Unicode
Language file font setting: FontToRenderThisLanguageInWin
Language file font base height setting: 0.00
Instantiate help controller
Load HelpController file
Loading help file, path: C:\Program Files (x86)\Resolume Arena 5.1.4\docs\help\English.xml
Load contextual shortcuts from disk
PropertyCollection, check for user configured keyboard shortcuts
PropertyCollection, no user configured keyboard shortcuts found
PropertyCollection, midi file path C:\Program Files (x86)\Resolume Arena 5.1.4\default\contextualMidiShortcuts.xml
PropertyCollection, dmx file path C:\Program Files (x86)\Resolume Arena 5.1.4\default\contextualDmxShortcuts.xml
PropertyCollection, osc file path C:\Program Files (x86)\Resolume Arena 5.1.4\default\contextualOscShortcuts.xml
Initialize quicktime
Create application controller
Create playback controller
Create audio/video plugin collection
Create composition object
Create video engine
Enumerating DeckLink Devices
Enumerating DirectShow Devices
Generic PnP Monitor NVIDIA GeForce GTX 1070 {7E34F87D-F393-4D06-B753-6E06E74BBCEF
Create audio engine
Load Advanced ScreenSetup Library
Advanced Screensetup library, load dll: C:\Program Files (x86)\Resolume Arena 5.1.4\ScreenSetup.dll
Advanced Screensetup library, Load message:
Advanced Screensetup library, set Application name and initialise
Setup Interface Advanced Screensetup library
Advanced Screensetup library, Connect to Composition
Advanced Screensetup library, Connect to DmxController
Create GUI
Mainwindow: create main component
Mainwindow: setup command manager
Mainwindow: create menu
Mainwindow: enumerate displays
Mainwindow: set bounds and resize limits
Move splash window to front
Video engine is enabled
GUI is present, call initGL on main window
OpenGLCanvas: New context is created
Initialise composition object
Initialise audio engine
Opening DirectSound device: Primary Sound Driver
Opening DirectSound device: Headphones (Thumper Boombox Stereo)
Opening DirectSound device: Speakers / Headphones (Realtek Audio)
Opening DirectSound device: Primary Sound Capture Driver
Opening DirectSound device: Microphone (Realtek Audio)
Opening ASIO device: Realtek ASIO
Opening Dummy device: Dummy Output Device
Opening Dummy device: Dummy Input Device
opening dsound out device: Primary Sound Driver rate=44100 bits=16 buf=2560
opening dsound out step 2
opening dsound out step 3
opening dsound in device: Primary Sound Capture Driver rate=44100 bits=16 buf=2560
opening dsound in step 2
DS error at line 628 - Device already allocated
Error opening Primary Sound Capture Driver: "Device already allocated"
closing dsound out: Primary Sound Driver
Failed opening audio device
Find audio plugins and add them to the plugin collection
Attempting to load VST: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\afx\Resolume Bitcrusher.dll
Creating VST instance: Resolume Bitcrusher
Initialising VST: Resolume Bitcrusher
Attempting to load VST: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\afx\Resolume Distortion.dll
Creating VST instance: Resolume Distortion
Initialising VST: Resolume Distortion
Attempting to load VST: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\afx\Resolume EQ-3.dll
Creating VST instance: Resolume EQ-3
Initialising VST: Resolume EQ-3
Attempting to load VST: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\afx\Resolume Flanger.dll
Creating VST instance: Resolume Flanger
Initialising VST: Resolume Flanger
Attempting to load VST: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\afx\Resolume High-Pass.dll
Creating VST instance: Resolume High-Pass
Initialising VST: Resolume High-Pass
Attempting to load VST: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\afx\Resolume Low-Pass.dll
Creating VST instance: Resolume Low-Pass
Initialising VST: Resolume Low-Pass
Initialise video engine
Init glew succeeded
---Info main OpenGL renderer---
Vendor : NVIDIA Corporation
Model: GeForce GTX 1070/PCIe/SSE2
OpenGL version: 4.5.0 NVIDIA 382.53
OpenGL version short: 4.5
OpenGL shader language version: 4.50 NVIDIA
GLEW_EXT_framebuffer_object supported
framebuffer_object enabled
GLEW_ARB_texture_non_power_of_two supported
texture_non_power_of_two enabled
Find video plugins and add them to the plugin collection
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGL3dPixels.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLAddSubtract.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLB&WMixer.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLBrightnessContrast.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLColorize.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLColourPass.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLCreateAlphaChannel.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLCrop.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLCubeMixer.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLCubeTiles.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLCut.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLDelayRGB.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLDisplaceMixer.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLDotScreen.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLFeedback.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLFlip.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLFreeze.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLGradients.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLGrid.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLInvertRGB.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLJitterBug.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLLumaWaves.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLMask50.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLMetaMix.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLMirrorQuad.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLMixLoRez.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLMixMultiTask.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLMixShiftRGB.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLMixToBlack.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLMixToWhite.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLNoisy.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLNoisyMixer.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLParticles.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLParticleSystem.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLPartsMix.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLPixelHighPass.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLPointGrid.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLPolarKaleido.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLPolkaDot.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLRadar.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLRotateXMixer.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLRotateYMixer.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLShiftRGB.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLSideBySide.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLSnow.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLSolidColor.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLSolidColorEffect.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLSparkles.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLStaticMixer.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLStingySphere.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLThreshold.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLTiledMix.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLTimeSwitcher.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLTint.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLTrails.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLTriangulate.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLTwitch.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLTwitchMixer.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLVertexControl.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLVertexControlCrop.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLVertexControlMask.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLWipeDown.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLWipeLeft.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLWipeRadial.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLWipeRight.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLWipeUp.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLZoomMixer.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\AVFFGLZoomMixerOut.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLAdd.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLAdd50.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLAlpha.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLBarShift.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLBlow.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLBlur.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLBurn.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLChromaKey.dll
Registering plugin license.
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLCircles.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLDarken.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLDifference.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLDifferenceInverse.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLDistortion.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLDodge.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLEdgeDetection.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLExposure.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLFishEye.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLHardLight.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLHeat.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLHueRotate.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLKaleidoscope.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLLevels.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLLighten.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLLighten50.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLLorez.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLLumaDisplace.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLLumaIsAlpha.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLLumaKey.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLLumaKeyInverse.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLMirror.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLMixRGB.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLMultiply.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLPosterize.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLPremultiplier.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLRGBASwitch.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLSaturation.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLScreen.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLSetMask.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLSlide.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLSoftLight.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLSqueeze.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLStatic-source.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLStatic.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLStopMotion.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLStroboscope.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLStrobosope-effect.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLSubtract.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLSubtract50.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLTile.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLTwirl.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\FFGLWaveWarp.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\InfiniteZoom.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\Lines.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\LineScape.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\SyzGL_Colourise.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\SyzGL_Fragment.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\SyzGL_Goo.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\SyzGL_Iterate.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\SyzGL_Kaleidoscope.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\SyzGL_RadialBlur.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\SyzGL_Ripples.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\SyzGL_Stripper.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\SyzGL_Tunnel.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\SyzGL_VideoWall.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\SyzGL_Vignette.dll
Load plugin: C:\Program Files (x86)\Resolume Arena 5.1.4\plugins\vfx\Terrain.dll
Advanced Screensetup library, Initialise
smoresahoy
Fixed by disabling Realtek Audio Driver. Tried rolling back a driver and that did not work. Not sure if this is a windows 10, realtek, or resolume issue.
good to hear that it works now.
We can confirm this can be resolved by disabling the Realtek drivers. The Realtek drivers are not required for Resolume to function normally.
So far it's only popping up on Dell computers, which is strange, since the Realtek drivers are shipped with pretty much every PC.
We're looking into whether this is something we need to fix, that Dell needs to fix, or Realtek needs to fix.
ttbagh
Post by ttbagh »
smoresahoy wrote:Fixed by disabling Realtek Audio Driver. Tried rolling back a driver and that did not work. Not sure if this is a windows 10, realtek, or resolume issue.
Thanks!!! that solved my problem
