I'm finding an increasing number of issues trying to make a custom touchOSC controller. After reading a lot of threads I assume that most of them, mainly the ones related to delayed or plain wrong OSC feedback from Res to touch OSC are caused by being on a wireless network, using a cable from laptop to router should fix this (I hope).
But I'm finding some very strange things. I added a label to display BPM and although it "works", if the BPM on Resolume displays 125.00BPM, touch OSC displays 0.24698795... Is there a way to fix this?
									OSC issues - BPM
Re: OSC issues - BPM
if you can do mathematical expressions in touchosc then you can calculate the value from the float.if the BPM on Resolume displays 125.00BPM, touch OSC displays 0.24698795... Is there a way to fix this?
the BPM range is
edit: the formula is: floatBPM*492+2 = BPM
