Hi to All,
In order to type and display texts the way we want in the club, I asked a guy to write simple flash code with several parameters to choose and we're stuck at the beginning because nor Arena 5.0 nor Arena 5.1 (Windows 10, checked on 2 machines) is not showing parameters panel. Resolume loads swf file and display "Lorem Ipsum..." text but no option to change anything.
Example SWF file "Resolume3ExampleSpringyAS3" works fine. Also rewritten and republished with the same settings as our new file, example works fine and our flash doesn't show parameters, so we asume it is not publish or flash coding software case.
What is more, iT works perfectly fine on Arena 5.0 on MAC but we need it on Windows.
Any idea how this problem can be solved?
Here goes 2 files if anyone would like to help and check on their computers. Would appreciate any comment or suggestion.
Text flash file doesn't show parameters on Arena Windows
- Attachments
- txt flash.zip
- (83.42 KiB) Downloaded 259 times
Re: Text flash file doesn't show parameters on Arena Windows
Update your Arena to 5.1.4 and it should be gone
~Berlin~
~Berlin~
It appeared that changing some names and not using some special characters in the code help.
Thanks for watching
Thanks for watching
