hey
to collaborate with my team on making decks, Ive moved my .avc files to a dropbox folder. I can load and resave .avcs fine here using the file menu, but if I double click to load a .avc from dropbox , it loads instead the last .avc file that was loaded from the Resolume/compositions folder.
Is it the case that Resolume doesnt want me to use other locations for .avcs? or should this work?
thanks!
Re: other locations for .avc
Create a symlink of the .avc file in your dropbox folder, and move the symlink file to the compositions folder in the Resolume folder.
well, having the actual avcs on dropbox means the team can all work on the same set of avcs which is what we want.
Exactly, so you keep the actual avc file in the dropbox and move the symlinks to the various composition folder on your team's computers.
yes got it, will try that
thanks!
thanks!
